I have in my domain usernames with german umlaute (ö,ü,ä).
With these username a Login is not possible. I have tested it with an other user and changed it to have such an character in the Name. No Login was possible. Then I deleted this character and the Login works.
Is there any Setting I can configure or do I have to rename the useraccount?
Username with german characters
Re: Username with german characters
Which connection method are you using and what version of TSplus ?
support@mm-forst.at
Hi!
We are using the integrated webserver with HTTPS on port 8443
TSPlus Version: 8.20.5.10
I recommend you to update to 9.10 as I believe this issue has been fixed.
