Tsplus on Azure
VAdmin
Tsplus on Azure
Post by VAdmin » Mon Feb 08, 2016 9:53 am
Does TSPlut works normally in Azure servers.I noticed that at every restart serial number is changing.Is anywhere offical pronouncement about Tsplus that supports Azure virtual machines.
Re: Tsplus on Azure
Post by admin » Mon Feb 08, 2016 10:29 am
Yes, TSplus supports Azure virtual machine. However you will need to update to the latest version as this serial number changing issue has been fixed.
VAdmin
Re: Tsplus on Azure
Post by VAdmin » Mon Feb 08, 2016 11:06 am
thanks
