We are using TSPlus 3 years.Everything is OK.But now we installed tsplus to Windows Server 2012 R2.
After this TSplus log on process began freezing.We are waiting at every log in 10-15 even 30 minutes.Welcome gif freezes in 40 %.
But Windows Terminal services is OK.And server has high recourse.
Please help
TSPlus session freeze 10-15 minute in log on
Re: TSPlus session freeze 10-15 minute in log on
VAdmin wrote:We are using TSPlus 3 years.Everything is OK.But now we installed tsplus to Windows Server 2012 R2.
Please help
We had a similar issue, but added the following to the login script
start explorer.exe
This work around seemed to fix the issue for us. Not sure if it is the same problem your facing though.
I tried your way but didnot worked for me(
What connection method are you using and what application are you publishing ?
Could you try the following :
- Assign the remote desktop application to one user.
- Open a session with a classic rdp client.
A slow logon is often due to either logon script that mounting network resource or process being launched at logon. You should be able identify the guilty process in the task manager / process tab and sort process by users.
