Printing on PDFCreator 2.2
luxinfabula
Post by luxinfabula » Wed Jan 13, 2016 1:42 pm
Good morning everybody
I've this problem.
I connect through grafic client to a server 2012 Foundation (Tsplus 8.5)
I've installed PDFCreator (same version) both on server and clients
When connected, I open a ERP based and installed on that server. If I want to print to pdf I can choose only the printer on the server, I cannot see the printer redirected by my client pc.... but I can see other client's printers. And so I cannot save easy the file to my desktop, for example
something wrong ?
thank you for your help
Umberto
Re: Printing on PDFCreator 2.2
Post by admin » Wed Jan 13, 2016 4:19 pm
Seeing other connected user's printer is quite common when using standard printer redirection. If old ghost unused printers are stacking in your printer list, you can use this procedure to clear them out once and for all : http://support.tsplus.net/kb/faq.php?id=21
You will not encounter this behavior if you use the Universal Printer as the unique printer.
You will find some general guideline on how to print below :
1- Universal Printer :
You will find here a good tutorial on how to print using TSplus : tsplus.net/support/kb/faq.php?id=20
2- Print redirection :
