Do seamless client will be further developed? But better to work with my applications than alternative RemoteApp. In the RemoteApp lack of options reconnect, poorly refresh menu items, windows applications do not always gain focus. It all works Idel in seamless client.
The only problem is green background in wnindows10.
Whether it will continue to support seamless client?
Re: Whether it will continue to support seamless client?
Even if the seamless client is not present anymore in the client generator, you can still use it with the switch -seamless on
This switch must replace the -remoteapp on switch if present.
You will find how to edit a generated connection client setting by following this procedure : http://www.terminalserviceplus.com/docs ... ted-client
The seamless will make an official come back when the support of Windows 10 is complete.
