Web access and NLA
Web access and NLA
When NLA is enabled, web access don't work. Users see fiew seconds of blue surface and then logoff. I guess that user actually don't log on server because NLA. When disable NLA, web login is normal. Our version is 8.20 and we don't know when this stops working, before it worked properly. For now, NLA is disabled but we want to use it because it helps security of server to be better. Do you have any suggestions?
