Jobs Stopping When Disconnecting
rwillen
Post by rwillen » Wed Jul 08, 2015 4:45 pm
We're in the process of testing out TSPlus on W8.1 and have run into an issue that we don't have when running standard RDP. Our users start jobs on that can take several days to run, with RDP they were able to disconnect from the session and the job would continue running. With TSplus the jobs get killed when they disconnect. Is there a setting I'm missing that will allow the jobs to continue running on disconnect?
Thanks!
Re: Jobs Stopping When Disconnecting
Post by admin » Thu Jul 09, 2015 3:37 pm
Yes you can do this.
Check the "Allow users reconnection when sessions are disconnected."
You can also set up a timeout for disconnected sessions which will cause a disconnected user session to automatically logoff after a while.
TSplus support team
rwillen
Post by rwillen » Tue Jul 14, 2015 12:12 am
Thank you, we will make the changes suggested.
