Interact with user's session without permission.
Dear Sir! While using RDP, I can interact with user's session without any permission from client side by using windows policy. How can I achieve it in TSPlus. Whenever I try to remote control a client's session, TSPlus request permission from client. Also when I remote control a session, TSPlus Diplays a message that I Can use "Ctrl + *" to end session, but that combination doesn't work.
Re: Interact with user's session without permission.
When in need to remote control a session without permission, simply use this command : mstsc /v:{server} /shadow:{sessionID} /control /noConsentPrompt
I have a user connected with TSPlus Server.
ID User Domain Status Session Client Name Client Address
3 Arif Active RDP-Tcp#65 ARIF -
Please tell me how to remote control it without asking for permission.
Did anyone solve this. No matter what I do, the user still gets the message that he has to authorise the connection. With mstsc.exe I get the message "Invalid computername" when I provide the IP-Adres and portnumber of my TSPlus server. Did anyone got this working and is willing to share the solution? Is there a commercial solution on the market?
Best Regards,
Aad
Best Regards,
Aad
There is no issue when using a recent release of TSplus.
If you are using an older release v12 or below you can check the following workaround :
- Set the group policy to allow Remote Control without user consent ,
- Then you can use the following batch file to shadow or remote control a session:
set /p session="Enter the Session ID to shadow:"
mstsc.exe /shadow:%session% /control /noConsentPrompt /noConsentPrompt
Different method integrated in TSplus :
Add the following line : sessionsmanager-showconsentprompt=no to the [Security] section of the appcontrol.ini file located in C:\Program Files (x86)\TSplus\UserDesktop\files.
Hi Olivier,
Thank you very much for you help. It's working perfectly.
Best regards,
Aad
Best regards,
Aad
