Hi I try to test program to inject setting in walkie-talkie from usb cable via port com 1 or 2..
Client we will use lite client and technician will be connect the device and put setting.
How I can map port com.
Best regards.
Port com mapping
Re: Port com mapping
Port com can be enabled in TSplus connection client by checking the com port box in the local resources tab.
Hi dear many thanks for reply, but I have the same problem I use sb cable like I will try I ind just one solution is to use this softwhareadmin wrote:Hello,
incentivespro.com/usb-redirector-rdp.html
there is another solution or option on tsplus
i use windows 7
bes resgards
Redirecting USB devices can be tricky. First of all I would recommend you to use the same version of Windows on client and server side. All clients and servers must be 32 bits or 64 bits and not a mix of both as it can lead to device driver issues.
In any case make sure you have installed the latest version of RDP client on all computers to ensure the best compatibility. Some exotic devices will have better chances to be redirected with RDP 7 or 8.
Some devices have also specific procedures for installing in a Remote Desktop environment.
You could also try out USB for RDP, which is cheaper and has good performance : rds-tools.com/usb-for-rdp/
Hi, dear sear many thanks for your reply an for your help.
very good job
best regars
very good job
best regars
admin wrote:Hello,
