HI
I have a huge problem!
I want do not delete data files on "C:\Users\Username\AppData\Local\Temp" . because my applications have some settings and when log in to app(first time) saving data in temp folder of users.
But when i log off from TS server , all data files in temp folder is deleted so when i reconnect to TSplus server, i must config first information for log in to apps.
I do not have any problem on other server that not installed TSPlus.
PLZ help Me to keep temp folder.TNX
do not delete sassion data!
Re: do not delete sassion data!
I suppose you are using an old version of TSplus, updating to the latest release should solve this issue. The only working directory for client is C:\Users\Nameoftheuser\RDP6
