Something very strange, but when I login using HTML5, the time is wrong, example; if it's 4PM, the server will show 4AM....
The strange thing is when I actually RDP into the 2008 R2 server, the fine is right.
Any help and suggestion is highly appreciated.
Cheers.
Wrong server time when login via HTML5
Re: Wrong server time when login via HTML5
I've just noticed this myself. It appears that Windows is showing Time Zone Not Recognized when logging in via HTML5.
Is there any way to set what time zone Web clients will use?
This issue has been addressed to our dev team and a fix will be soon available.
If anyone has this problem, I have a workaround. It doesn't get the actual time zone, but at least it will set the server's timezone, or whichever one you select. If anyone is interested, email me privately (jh1440 at gmail.com), and I'll send you the instructions. Currently, the workaround has been tested with Server 2008 R2. Not sure if it works on other versions.
Hopefully, the developers will deal with this properly soon.
Thank you.
Jeremy Heymann
Thank you.
Jeremy Heymann
Thank you for this, we will try to implement your solution to TSplus very soon
