Hi All,
I recently updated from v7 to v8 (Server 2012 R2). It seems in v8 there is no longer the option to disable (or set a time for) the option to log off users after they disconnect.
Our users are often moving around and like to simply disconnect from one computer before connecting from another. Since the v8 update, I can no longer find this option, and the default option is to log users off after disconnect, which I don't want. Can someone please advise how to fix this?
Do NOT Logoff users after disconnect
Re: Do NOT Logoff users after disconnect
You can set up a timeout for disconnected sessions. In the AdminTool, click on the Server tile and click on "Group Policies (GPO)"
Thanks for that - all fixed up now.
