How to create Folders for apps
hi
i have many apps(finance app, reporting,office apps ,...)
i want to create folders or groups for my apps and show on homepage clients just folders, users click on folders for see,use sub apps
Instead of displaying Apps, Displays apps Folders.
tnx
tnx
Re: How to create Folders for apps
I'm still waiting for your helps
tnx
tnx
Sorry for the delayed answer, you'll find our documentation regarding this subject here : tsplus.net/support/kb/faq.php?id=9
please stick to english language so that everyone can understand.
ok sorry...
I do this by assign floating panel on web.
Then i use "one folder specific folder content" in the "application preference" on floating panel costomization window. (to show my specified folder's content in application panel)
Then i copy som folders and applications shortcut in this folder so they are shown in application panel .
then I am using windows security on this folder for my users to read and execute permission only.(so that users cannot delete or edit on this folder's content from floating menu)
************************ A MISTAKE ****************************
but after minimizing an application it cannot be restore back to maximize.
It is a BIG mistake that minimized application has no Botton for remaximize it.
thanks for reply
thanks for reply
If you want to have a better behavior for minimizing your remote applications, you should consider using the remote app connection client. This mode of connection is supported if your TSplus server is installed on a Windows Seven / 8 Ultimate, 2008/2012.
If you cannot use the RemoteApp connection client, you can set up a different behavior for minimizing your applications. Open an admin tool, server tile, click on "Desktop Taskbar", make sure to uncheck the "Hide systray icons". If this is not enough you can also rename the file ltaskbar.exe into xltaskbar.exe located in : C:\Program Files (x86)\TSplus\UserDesktop
Then Open C:\Program Files (x86)\TSplus\UserDesktop\floatingpannel.ini
In [applicationpanel]
Add the variable
Maximize=yes
TSplus support team
Add the variable
Maximize=yes
TSplus support team
