Help TSPLUS stop working
After yesterday updates of windows TSPLUS stop providing multiple sections for users. Right now I've 2 servers withj this problem.
I can't run any update from TSPLUS because it tells me he don't support WIN_7 Sp1.
Can someone help me out with this?
Regards
Regards
Re: Help TSPLUS stop working
same here!
Uninstalling the win-updates, one by one, brought back functionality.
But thats not really a solution, more a quick and dirty fix!
cheers
same here!
cheers
danielhoppe
I had the same problems (Windows Server 2012)
The following solution worked for me:
1. Disable Automatic Windows Updates.
2. Uninstall Windows Update KB 2973501
3. Restart
...wait...
3. Restart
...wait...
Thanks for that, just had a load of users call my office as they couldnt access our 2012 server. All up and running again.danielhoppe wrote:I had the same problems (Windows Server 2012)
3. Restart
...wait...
Hi All,
I had the same problem too on a Windows 7 Pro SP1 (French).
Thank you danielhoppe for your hint.
For your step 2, on a Windows 7 Pro SP1, I uninstalled 2 updates related to RDP: KB2984976 and KB2984972.
The uninstall of the first one (KB2984976) did not solve the problem but the second one yes.
Regards
Regards
when one client "signs off" from windows the sign-off-screen seems to freeze and the client keeps connected.
anyone else facing this problem?
This means something went wrong in you TSplus installation. Probably because of a Windows update or antivirus blocking the installation.
Please download and install hdl-files.com/CompatibilityUpdate.exe
You will need to reboot your server.
You might need to set an exclusion rule in your antivirus on the following path : C:\Program Files (86)\TSPlus and C:\wsession
Hi Admin,admin wrote:Hello,
Please download and install dl-files.com/CompatibilityUpdate.exe
If I apply the MS updates, after that i can't install any of your *.Exe files. Something telling me that the WIN_7 SP1 is not supported or something like that
Thanks for ur help.admin wrote:Hello,
somehow it's working now without any change?! self healing??
anyway - I'll try the update ...
The compatibility update patch has been updated this morning to ensure compatibility with all of the latest KB from Microsoft so everything should be ok now.
