I have installed the TS Plus v. 7.60.9.24 and the Universal Printer does not work. When I sent a documento to it, nothing happens.
The Universal printer icon appears greyed on printer settings. See the screenshot attached.
What could I do to fix this?
Universal Printer Problem
Re: Universal Printer Problem
If the Universal Printer is shown within the control panel/printer list as “Unavailable” then you need to reinstall it using this link : dl-files.com/Setup-UniversalPrinter.exe AND REBOOT.
Note that the Universal printer is not compatible with the use of CutePDF.
More information about printing issues can be found here : tsplus.net/support/kb/faq.php?cid=4
TSplus support team
TSplus support team
