Strange windows issue..
axl936
Post by axl936 » Thu Aug 07, 2014 3:36 pm
Hi !
i' ve installed ts plus on a windows 2008 r2 server in a ESX virtual enviroment, an i have a strange problem with some windows..
For example, in excel 2010, if i right click in a cell and then "properties" on it, i gen only a "piece" of properties windows.
Then if i minimize and successively maximize the rdp session i can see the entire window..
This problem will appear with print preview (the screen is flickering), and in many other situation.
All sw is updated (windows, office, tsplus)
I have tryed with ms rdp client, ts plus client, max and min colour deep, performance settings on windows client and server, disable all effects in local and terminal session, but the problem is still active !
can someone help me ?
Re: Strange windows issue..
Post by admin » Fri Aug 08, 2014 10:03 am
On W8 and Windows 2012, Microsoft is installing a default standard graphic driver that is not enough compatible with some applications and the new Metro interface. As result some application are flickering.
In order to avoid this annoyance, we have develop a patch that you can download using the following link:
dl-files.com/BlinkingPatch.exe
Just run it as administrator and reboot.
After the reboot, the users shall not have any more blinking/flickering annoyances.
If you still have some performance issues with Office 2010, install Office 2007 ! Office 2010 and 2013 are know to have flickering issues when used in RDP environment.
