Web Credential for HTML 5 Clients log on problem.
Robert
Post by Robert » Mon Jul 07, 2014 5:30 pm
When Web Credentials was enabled in TSplus version 7.30 and at the web log on page, the user enters a user that is not on the web credentials list, a message saying “Invalid Credentials” is displayed and the user returned to the log on web page to try again. In TSplus version 7.50, if the user enters an invalid web user name or password, the user is sent to the windows log on screen, which is wrong, because if Web Credentials are being used, then legitimate users are not going to know their windows log on anyway and it is difficult to return to the web. Is there a way to have the same handling of invalid logs on with Web Credentials was enabled as before (e.g. just the message, then return to the log on screen? This is very important to us.
Thanks,
Rob
Robert
Re: Web Credential for HTML 5 Clients log on problem.
Post by Robert » Fri Aug 29, 2014 6:17 pm
Just to let everyone know this problem was fixed in 7.60.
Rob
Alpin
Post by Alpin » Fri Feb 09, 2018 2:22 pm
This post is very helpfull !
The problem is back ! Version 11.10.1.22.
Regression ?
IvanGB
Post by IvanGB » Fri Feb 09, 2018 6:26 pm
Hi Alpin.
Thanks for the heads up, but we are in the same version, using exclusively HTML5 connections and I could not reproduce this behavior.
Cheers.
Ivan
