I have another problem with the universal printer.
I'm running some clients (windows 7) with remoter APP, the client was generated using the client generation of the software.
The problem is when I try ti print something with the universal printer, it does not work, it mean the printing job do not appear locally in my PDF reader
This problem is only with windows 7, my clients running windows xp prints well
Please help me
Jose
Universal Printer does not work
Re: Universal Printer does not work
Sometime security software such as antivirus/firwall can block the print transfer on client side, disable your antivirus for 5mn, launch your connection client and try again. If you using adobe acrobat reader on client side then I recommend you to install FoxIt and try again.
Note that the Universal printer is not compatible with the use of CutePDF.
More information about printing issues can be found here : tsplus.net/support/kb/faq.php?cid=4
TSplus support team
TSplus support team
