Problem folder RDP-Tcp
rpce
Post by rpce » Sat Feb 15, 2014 10:20 pm
When printing on a server in the profile directories are created which seems to me should be deleted and they are not.
c:\Users\[users]\AppData\Roaming\RDP-Tcp#?
RDP-Tcp folders with another numnerem appears as many times to print.
You can do something about it?
Re: Problem folder RDP-Tcp
Post by admin » Tue Feb 18, 2014 1:10 pm
this temporary folder are made upon connection and contains a few configuration files and should not affect your server.
rpce
Post by rpce » Tue Feb 18, 2014 5:20 pm
Ok I understand, but how many will be up to these directories? As much as prints or perhaps a limited amount?
Post by admin » Tue Feb 18, 2014 6:22 pm
I do not have any clue regarding this !
It only occurs to me that this has never been an issue for anyone.
rpce
Post by rpce » Tue Feb 18, 2014 7:56 pm
No not the problem it is not.
I just want to keep some order in the catalogs.
Not good but would not be limited to the amount of these directories.
