Allow only one open session per user not work
i install TSPlus v7 (last version) on Windows 7 & Windows 8.1 for test and select the option "Allow only one open session per user" but the users can connect two or more sessions from the same computer (and IP)... or from diferent computer.
can you help me? please
Re: Allow only one open session per user not work
I cannot reproduce this issue, to me this feature works well. What is the exact version of windows you are using as a TSplus server ? This feature may not work on a home version of Windows.
We use windows 7 Enterprise to 32Bits virtualized in Hyper-V 2012 and the same issue is with my that have installed Windows 8.1 Enterprise to 64 Bits
In this case I suppose group policy are handled by a domain controller which has priority over the local strategies that we change. So I recommend you to to change this strategy directly on the domain controller. Below a screenshot of the domain strategy to be changed.
