Universal Printer don't work
wasenbr
Post by wasenbr » Tue Nov 19, 2013 12:16 pm
I'm using the TSPlus on desktop with seamless client and the Universal printer don't work properly.
I've configured to print on windows default printer but it open a local PDF or simply doesn't nothing. If I configure as "select a local printer" it do the same thing.
My version is 6.50.9.26.
What can I do?
Re: Universal Printer don't work
Post by admin » Fri Nov 29, 2013 3:49 pm
I recommend you to update to the latest release and generate a new connection client. This should solve your issue.
