Demonstration Expiry
bobbyjo
Post by bobbyjo » Sun Sep 08, 2013 5:12 am
Upon expiry of the demonstration, TSPlus blocks login from Remote Desktop, as I don't have an "Administrator" User on my server this is an issue and everything is controlled by an AD domain. Going forth I would like to buy TS Plus at some point, that said upon expiry of should not block administration, instead I recommend falling back to single user mode and displaying your message. The consequences of this could be an issue.
Something to consider in the future.
Re: Demonstration Expiry
Post by admin » Wed Sep 18, 2013 5:39 pm
You should be able to logon to your server with a domain account with admin rights. If not then you may have to add users to the local "Remote Desktop" group. Hope this help.
nadav
Post by nadav » Sun Dec 08, 2013 6:12 pm
I'm experiencing the same problem.
I am an administrator for the domain and still I cannot access the server running TSplus.
Just to make sure, I have added personal permissions for my user on the computer account - no change ...
I was able to login remotely before the installation of TSplus, and during the trial period.
We have already purchased TSplus, but I have no way to put the license in...
Off-course, I have no access to the console - I wouldn't be bothering you if I did ...
Please advise ASAP.
Thanks,
Nadav.
Post by admin » Fri Jan 03, 2014 2:53 pm
Uninstalling TSplus will give you back your admin remote access.
