TSPlus Support
Why doesn't the numberpad, arrow keys do not work over HTMLS 5 connection?
The number row above your letter keys work but the numberpad on the right side of the keyboard do not work. This is a huge showstopper from me using TSPlus. Especially when I use the PC for financials and must be able to use the numberpad and arrow keys on the keyboard.
Is there a way to enable them?
Numberpad and other keys on keyboard do not work
Re: Numberpad and other keys on keyboard do not work
I discovered the outside the browser java client works fine with numberpad no issues. Its a problem within the browser clients that are the issue.
Please fix or let me know of any configurations I can change to allow it to work.
I received a response from TSPlus support that resolved the issue
We have reproduce and fixed this issue.
Can you edit html5.html and change:
var preferchars = false;
to
var preferchars = true;
Also make sure that you set var lang= to your own language keyboard (for example "en_en")
or "us_us" or "fr_fr" in your index.html file.
This should be enough to fix the problem
Last detail: delete the cache files on your IPAD
Kind regards
John
