Can anyone help with the above problem. We have used TS Plus to hide the C,D and W drives which it does, but when users are connected to our Server through our generated client shortcuts they can file save to any folder and also navigate back through the folder tree to other folders. Realise its probably not a TS Plus problem but can anyone help maybe hiding the Windows explorer path/address bar?
Michael
Prevent users from accessing other server folders
Re: Prevent users from accessing other server folders
You can find more information about this subject here : http://tsplus.net/support/kb/faq.php?id=19
If you wish to totally mask everything that could appear from an explorer window I know there are some security tool out there that can do it.
Brilliant thanks, i was applying GPO's to all users including Administrators.
Michael
Michael
