Is there an option to disable the file transfer window appearing when using 'Shift+F' through a Users connection. When our clients connect using a generated client the only way to type a capital 'F' is using Caps lock.
Michael
Disabling TS Plus File transfer
Re: Disabling TS Plus File transfer
Resolved
In Admin Tool 'Edit .INI parameter files'. AppControl - change hotkeyFTP= i left it blank and Loadbalancing [filetransfert] hotkeyFTP= i also left this blank.
It resolved it for our customers.
johndavies
In fact if you apply the latest Update (5.97) you will not have anymore file transfer because we have remove it.
We want to replace it by something much better but the development is not completed yet.
http://tsplus.net/UpdateRelease.exe
Kind regards
John
Kind regards
John
Thanks John
