MAC OSX Login from HTTP JAVA Issue
bijan
Post by bijan » Wed Oct 31, 2012 7:43 pm
If you are having problems logging in from your MAC using the JAVA option, check the following setting in your Java Preferences.
Using the spotlight tool, search for "Java Preferences"
Under the General Tab make sure the Enable applet plug-in and Web Start applications is checked.
I just wanted to share this.
Regards
Bijan
johndavies
Re: MAC OSX Login from HTTP JAVA Issue
Post by johndavies » Fri Apr 18, 2014 9:44 pm
Thank you Bijan :D
Kind regards
John Davies
