I am unable to successfully launch the TSPlus application client under windows server 2003.
I does all the right things connecting etc but then nothing happens.
What am I doing wrong?
Cheers
David
Windows server 2003 client compatibility
Re: Windows server 2003 client compatibility
Windows 2003 server is supported for the use of TSplus server and client. Make sure you typed the correct IP address in your generated client by checking out this FAQ and try again from another computer : http: //tsplus.net/support/kb/faq.php?id=24
TSplus support team
TSplus support team
It is the same client I use on all other computers.
I did forget to mention that I am running within a Microsoft TS client on windows Server 2003 (Not TSPlus).
So I want to log into windows server 2003 TS client and run an application on a different TSPlus server.
Cheers
David
Cheers
David
This is strange... If your client works everywhere but on this specific server then it seem to mean that maybe you could have something blocking the network traffic on TCP port 3389 like a software firewall / antivirus ? Using any RDP client other then TSplus should works also, there are no limitations about this.
TSplus support team
TSplus support team
