when we copy an exe from one machine to the other is shows a security error...
Can you please advise if there is a way bypass this security.
Thank you
Problem with transfering file...
Re: Problem with transfering file...
To avoid the security warning pop-up, I think you should edit the .exe property.
You will see a button on the bottom right side "Unlock". Click on this button.
Kind regards
Paul
Kind regards
Paul
