I am moving my domain and my ISP is very unhelpful and keep saying that I am in danger of the domain being deleted.
This would be a disaster as none of my users would be able to access the servers.
To be careful I decided to copy the original connection clients and amend them using the ConnectLauncher which does make it quick and easy.
However, it occurred to me that TSPlus could add a second server setting in the ClientGenerator so that if the first one fails it could automatically switch to the other setting.
so https://mydomain.co.uk port 443 and 213.123.199.448 port 443 could be setup.
IP addresses & domain setup
Re: IP addresses & domain setup
This probably mean that you did not renew your subscription to your domain name. You need to check this with your DNS provider.
My domain is on continuous renewal and that issue was just me describing my thinking.
My suggestion is:
It occurred to me that TSPlus could add a second server setting in the ClientGenerator so that if the first one fails it could automatically switch to the other setting.
My suggestion is:
