In the past I have managed several TSplus installations at multiple small companies.
However my biggest customer used to use Citrix and then switched to another package now owned by Parallels.
To be honest using 2X applicationserver was intuitive and I could install it under 15 minutes on any terminal server, which could not be said of Citrix Metaframe.
Sometime ago, this customer ask me to update their servers to Windows 2016 (2x 60 users), upon seeing the new license fees for their current RDP package, the customer asked me for an alternative and I suggested TsPlus.
I installed a demo on their new server, but being accustomed to 2X they found it less user friendly and are considering staying with 2X despite the steep price.
One of difference the customer noticed immediately was a missing shortcuts on their desktop.
This is a feauture with both 2X and Citrix have.
Because of this, most of the customer's staff even think they are working locally!
I have some features suggestions I would like to have with TsPlus to make TsPlus more likeable to the customer.
In my humble opinion, the user should (almost) not be aware he or she is working on a remote server.
To establish this I have some feature requests on top of the TSX app.
First add a secondary / backup host list, to connect to.
If the primary host is not available, then connect to the secondary, thertiary.... etc host.
The customer has the same host connected to 2 highspeed internet connections, so if 1 goes down, it would be
great if the app would (re)connect via the other connection.
(Or if you just have multiple host, the client could connect to the backup one automatically when needed)
Also a separate field for the host port, would be nice.
The default port is 80/443 but I like to change that.
It makes it less easier to hackers to hack your server, if they don't now your access port.
I know adding :portnumber behind the host or IP is possible, but a separate field is a cleaner solution.
Third I would like to be able to make shortcut from the published apps I see in the TSX App.
Preferabaly with the the App's own icon. This icon could be extracted from the app, and put in the user's profile.
The internal working could use the .connect protocol.
(BTW, the competitor mentionted earlier uses a shortcut to a file TSClient.exe on the client with parameters in which the password is encrypted.)
Furthermore the App starts within the TSX App window. To have a clean user experience I would suggest Apps starting from the
using the TSX App, to start as independed app (like .connect), but showing their own icon in the taskbar.
Last to make an 2018 impression
smaller e.g. a small windows with the text: "NNNNN app connecingt to server XXXXXXXXX".
Also the big windows saying "signing off" is not so cool
Please let me know what you think of my idea's?
If something is not clear, tell me and I shall explain it more in depth.
Best regards,
Joshua.
