Copy / Paste Function
fakebrains
I was wondering if there is any support for copying and pasting images locally to our application through the HTML5 gateway. I know text is supported but one of our users has brought up that they have successfully been able to copy an image locally and then paste into our application through the HTML5 gateway. I have been able to test this and every once in a while it does in fact work (on occasion). I wouldn't mind replicating this further as it seems easier than uploading and attaching the image through the drop down menu. Do you know if there are any settings that we can tweek or anything that can accomplish this on a more constant basis. Is there a FAQ anywhere to read on limitations ?
Re: Copy / Paste Function
This cannot be supported because HTML5 is a pure web connection mode. You can however transfer your images using the file transfer tool : https://docs.dl-files.com/tsplus/html5- ... e-transfer
