in web edition i can only configure "Binary" Applications with a executable that run in new ts-plus session.
It will be a nice feature to have the option to configure also "a real web" application. This is only a web URL and a Icon.
So after web login you have like binary apps a icon and a app name for web app. On click on the icon a new tab will be open with the configured url. This is very useful to propagate intranet applications in same way like binary windows applications.
A customer wich use TS-Plus use Internet Explorer and Parameter=URL to realize this.
Best Regards
Frank
Suggestion of feature for Web Edition
Re: Suggestion of feature for Web Edition
Not sure if you're looking for the UrlOnClient function:
"C:\wsession\UrlOnClient.exe" "http://some-web-site"
As Hansen suggested, using the "Url on client" feature might be what you are looking for, more information about this can be found here : http://www.terminalserviceplus.com/docs ... lient-side
