Was editing Web Portal Design and accidentally pressed Reset.
I did NOT press Save and it lost all my settings.
The Reset should only commit the changes if Save is pressed or, ask if you are sure you want to reset the settings.
Cheers
David
TSPlus 8.4 Bug
Re: TSPlus 8.4 Bug
I forwarded your request to our development team, thank you for your feedback.
Re: TSPlus 8.4 Bug
A confirmation dialog has been added and will be included in our next release.
Thank you,
Adrien
Thank you,
Adrien
Adrien
TSplus CTO
TSplus CTO
