Application Menu Problem.
In the Application Menu require a check of valid credentials before displaying the assigned applications.
				johndavies
Re: Application Menu Problem.
I think you need to apply the Update Release on your system (and reboot)
The behavior you are describing does not look like what we see on our test lab systems.
For the display application, it should be the Desktop that is often assign to the Administrator account.
The icon is the expecting one but the display name is pointless.
Hopefully, after the update, this will be fixed too.
Kind regards.
John Davies
Kind regards.
John Davies
