On some servers there can be more than one IP address assigned to a network card.  In such cases it would be helpful to be able to specify the IP address that the TSPLus web server should listen on just as you can specify the ports.  Then you could ensure that TSPlus is using a particular IP Address just as you can in IIS8.
Thanks,
Simon
						Allow the ability to specify IP address for web server
Re: Allow the ability to specify IP address for web server
It would add a great deal of complexity to add such a feature, and it is not directly related to TSplus.
