What's new in 8.30
What's new in 8.30
i found no Information here.
Re: What's new in 8.30
The release note is coming very soon.
What is "very soon" ???
The release note will be sent to all tonight.
The release note for 8.30 is taking longer then expected to deliver as our development team is working on a fix for the following bugs, this next minor release should be available Monday 6th :
This update includes the fixes related to the color:
- Seamless clients where half of the screen is not seamless
- Black color background
- RemoteApp bugs because of colors issues ...
We added for the Administrator the freedom to select his prefered backgrond color.
This new feature is added to the "Session Opening Preference" tile.
This version is including the fix of Web Application Panel when a Domain is used.
The Getsuserlist.exe and the ApplicationControl.exe programs was using a lot of CPU when a large number of users/groups was handled by the programs.
We added sleep commands to avoid it.
For HTML5 the support of W10 new IE has been extended.
The Domain name is now stored without domain extensions.
Comment: even if this 8.30 release is including most of the requested fixes, we do not consider it as the final 8.30.
The assign servers to groups is still not yet developped and we are studying the option to completly eliminate the users.txt, groups.txt and domain.ini from c:\wsession.
An issue with application assigning has been detected, this release will include more stability to this feature.
- FIXED: when publishing the TSplus taskbar
the published applications was (sometimes) not displayed
A small "HIDE1" windows was displayed
sometime a green background was displayed
- FIXED: when publishing the TSplus taskbar in seamless
sometime the seamless was not applyed
- FIXED: when publishing the TSplus taskbar in RDP or Java or HTML5
the prefered color of the AdminTool was not applyed
- FIXED: When an AD have several sub domains, the application assignent
was not handle according to each sub domain
