When using Universal Printer, a pdf-file is send to the clientmachine. Is there a way not
sending a pdf-file, but sending the printout directly to the browser and print from there,
like a webpage does.
Thanks for any reaction.
Best regards,
Aad
Printing in browser.
Re: Printing in browser.
The Universal Printer will always convert any print job to a .pdf file. However you can change its behavior when generating a connection client in the local resource tab : terminalserviceplus.com/docs/universal-printer
If you are using the web client, you can also tune it to your preference in the web tile of the admin tool / Windows/java Printing options.
