i trying ts plus 7.30 by using remote application
my suggestion is to add an option alowing adminitrator hiding every dialog box or screen (windows login /logoff screen ) , connection .....
so the application will seem like a real web application
thank you
hide dialog box/ windows logon/logout screen on connecting
Re: hide dialog box/ windows logon/logout screen on connect
+1
That would be nice if possible!
Best regards
Jeffrey
+1
Best regards
Jeffrey
hi
i think that is possible and i' m waiting for tsplus comment about this sugestion
Best regards
Best regards
This is not doable at this time. We encountered many technical issues which prevented us from being able to achieve this.
You can extend the current spashscreen out a bit longer which can help hide the login process.
If you open the following file
Change the 3000 to something higher (this in milliseconds) like 8000 or 10000 and it will help cover the login screens.
Also you will notice the long Base64 encoded string. This is the spashscreen.
If you decode it in something like this, base64decode.net/, you will get the real html
If you remove the "onclick" part it will stop the ability to click on the spashscreen and have it disappear.
We have modified our splashscreen to fit in with the styles of our web product and have the same background colour.
I also have the background of our desktop the same as it so the transition from our web product to our legacy win32 product is very seamless.
and look for the code below you will see two timeout values. 3000 and 5000C:\Program Files (x86)\TSplus\Clients\www\software\html5.html
Code: Select all
<script type="text/javascript">
var splashscreentimeout = false;
var splashscreencontent = "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";
function splashHide() { window.setTimeout("window.splashHideIm();",3000); }
function splashHideIm() {
if(window.splashscreentimeout) {
window.clearTimeout(window.splashscreentimeout);
window.splashscreentimeout = false;
try {
var k = document.getElementById("splashscreen");
if(k) {
$('#splashscreen').hide();
while(k.hasChildNodes()) { k.removeChild(k.lastChild); }
k.parentNode.removeChild(k);
} catch(e) { }
window.addIframeMenu(0);
function myOnbeforeLoadHTML() {
try { if(window.stopexec) { return; } } catch(e) { }
window.myOnbeforeLoad();
$('body').append(window.jsdecode64(window.splashscreencontent));
if(!window.splashscreentimeout) { window.splashscreentimeout = window.setTimeout(function() { window.splashHideIm(); }, 5000); }
</script>
Code: Select all
<div id='splashscreen' onclick='window.splashHideIm();' style='text-align:center;position:absolute;left:0;top:0;margin:0;padding:0;width:100%;height:100%;background-color:#FFF;text-align:center;z-index:1111;'><br /><br /><br /><TABLE BGCOLOR='#FFFFFF' BORDER=0 BORDERCOLOR='#FFFFFF' CELLPADDING=0 CELLSPACING=0 width='100%'><TR><TD WIDTH='100%' HEIGHT='100%' BGCOLOR='#FFFFFF' ALIGN='CENTER' VALIGN='MIDDLE'><br /><br /><h1 font-family: Segue UI; style='color:#68838B'> Your online security is important to us.<br /> Please wait while we secure your connection ...</h1><br /><IMG SRC='html5/imgs/ring64.gif' BORDER=0><br /><br /></TD></TR></TABLE></div>
