New TSplus release:
- This release includes our brand new RDS-Knight v4! More details on: https://dl-files.com/RDS-Knight-changelog.html
- Connection Client: pressing "Enter" key now triggers connection in TSplus login/password input dialog
- Connection Client: fixed wrong credentials used when running a *SSO client and a standard client on the same workstation (#2845)
- System Audit: fixed Windows Server 2008 SP2 specific bug causing AdminTool to crash when launched
- System Audit: removed "prints" folder check, as this folder is always created when required so the System Audit check is pointless and generates support wrongly.
- AdminTool: Session > Session Management: "Terminate any disconnected session after" now accepts values lower than 15000ms (down to 5000ms)
- Web Applications Portal: fixed an error when using Web Applications Portal with 2FA
- Shell: WinXShell is not enabled anymore by default on Windows Server 2019 and Windows 10 1809 and newer.
- OpenSSL dependency: updated to OpenSSL 1.1.1b
- HTML5 v6.21: fix for canceled uploads when user logon contained space(s) inside
- HTML5 v6.22: some small fixes
- 2FA: added a new setting to configure the "issuer" text on the user 2FA mobile application ("Issuer=XXX" in "twofactorauth.ini" file)
- 2FA: fixed potential issue with licensing details display
New TSplus Release 12.20.3.12
Re: New TSplus Release 12.20.3.12
Thanks for implementing the "Enter" feature for the Connection Client.
So for using the new "Enter" feature on my clients, i have to run the new Setup-ConnectionClient.exe on the local clients, correct?
regards,
Michael
regards,
Michael
the answer is yes.
Thanks, works fine.
Michael
Thanks, works fine.
Michael
I like when you do question / answer like that. Glad you like it.
.connect file created by Windows Server 2012r2 (English) cannot be run under
Windows 7/10 Chinese OS( 936zho collation)
