New Major Release 11.50
A new version of TSplus is now available.
Major release 11.50
- The licensing code has been greatly enhanced to enable new features. It pave the way for
TSplus license management and License Portal upcoming changes. For more information on the new
license capability (Volume License scheme), please contact us.
- When a new user account is created, the system does not display the Full Desktop at
the very first connection.
- The Full desktop is displayed when no application is assigned and when
the Microsoft Remote Desktop application is assigned to a user or to a group.
- When the Administrator is using the AdminTool to request the download of the UpdateRelease.exe
program, instead of having to download it and install it from the Download folder when
the download is completed, the AdminTool will do these tasks automatically.
- In the client generator the local resources are selected as default settings. Many customer do not
understand that they have to do it to enable COM port or printer redirection. It is better to avoid
this kind of misunderstanding.
- The Session Management (GPO) code has been completely rewritten. It was a old code that
never did change for years. The goal is to make it easier to understand for the administrator.
- HTML5: The latest HTML5 code has been included into this new release 11.50.
We added a file picker feature with the ability to set filters on file extensions to limit the upload
capabilities to allowed files.
It support on-copy event process execution.
The latest release of IE Edge is supported.
It enable the use of third party web services and it allows to pass SSL+HTTP traffic to third party
web servers. This can help customers wanting to stay with Microsoft IIS server.
Major release 11.50
Re: New Major Release 11.50
A new version of TSplus is now available. It is version
Including the latest release of RDS-Knight where
- Fix whitelisted IP blocked by Homeland Access Protection
- Fix One Click to Secure Desktop settings not applied for least-privileged user accounts
- Fix RDS-Knight-Session crash at session logon
- Updated French localized labels
- Updated IP to Countries list
Adding the Uninstal tile in the AdminTool.
his tile was displayed in the former release but removed in the release 11.50.
Update Release patch: http://dl-files.com/data/UpdateRelease.exe
"- Updated French localized labels"
Maybe you have to check the german localized labels and other gui elements too. Some of them are not completly readable, because there are not big enough.
Thanks.
Michael
Please open a support ticket with the sentence to correct so that we can make the appropriate changes
Thanks.
Michael
- Fixed compatibility with latest Windows updates
- Fixed "Activate your License" button missing
- Fixed "msvcrt120.dll missing" error message in Free Certificate Manager
- HTML5: fixes for new Chrome and Firefox versions
- HTML5: fix for specific print bug on old Windows version with Firefox
A new version of TSplus is now available. It is version 11.50.9.4
- HTML5: fixed a graphical bug on Server 2003
- HTML5: better mouse events handling
- HTML5: mouse cursor handling rewritten
- fixed a Volume Licensing bug in Setup
A new version of TSplus is available. This is release 11.50.9.10
- TSplus supports now more than 16 RemoteApp sessions
on W10 and W2016.
- Opening a session with standard RDP client mstsc.exe has never be as fast as now.
- The logon process has been optimized
- The Session Manager option "The second session will be logoff"
was alway selected. It is fixed now.
- One command line has been added for a customer expecting to use
the Microsoft Gateway instead of TSplus Gateway.
on W10 and W2016.
A new version of TSplus is now available. It is version 11.50.9.16
- An error was display when installing on a system without Internet access.
It is fixed now
- In Web Application AND for the RemoteApp mode, AND
when Folder.exe application is set with a specific folder (for example : C:\Myfolder
it was the user Desktop which was displayed.
It is fixed nox
- HTML5: the new version include new security features and some enhancements
for a better support of old IE versions
- Logon process has been optimized
- RemoteApp support on W2016 has been enahnced
Comment: We do expect to publish the release 11.60 begining of october.
It is fixed now
It is fixed nox
Major release 11.50.11.25
- Include the support of the latest KB
- To enhance security 3 services are now started with Local Service instead of
System Service with restriced privilidges
- To enhance security, in /WWW folder, the "Users" grant Write rights only on /PRINTS and on /DOWLOADS sub-folders.
- To enhance security only Admins and System can access to /cgi folder
- To enhance security the latest release of Ghostscript and openSSL are included
- RemoteApp on W2016 fix on W2016 was not properly set.
It is fixed now
- The candidate release of the new Alternate Shell (WinXshell) is now included.
It eliminate the limit of 16 users (black screen) on W10 and W2016.
- The GOP tile idle time was not correctly set.
It is fix now
- On W10 / W2016 the GPO tile is adding the feature to disable services "per user"
This is reducing the users logon time
- The logon time is faster even when using mstsc
- Sometime RemoteApp was showing a blue background.
It is fixed now
- HTML5 speed and security has been enhanced
- The Client Generator does not display anymore the "Client Serial number security" because it is pointless as we do not use a .exe program anymore
- The Setup has been changed to enable installation on servers where the system in not installed on C: drive
It is fixed now
It is fix now
It is fixed now
vivburrows
11.50 26 sept
All servers we have updated to this latest version are erroring when printing
Servers Win7 x86 and x64
If users login via an rdp client and print, the universal printer errors immediately
If users login via a browser the print is successful
Open an admin tool, click on the license tile and perform a "Current system audit". Reapply the latest update if an error shows up and reboot.
- Check the presence of two universal printer driver. Open a control panel / Devices and Printers click on the universal printer and click on "Print server properties" and click on the drivers tab. There should be either the CustPDF driver (old driver from version 9 and below) or the GhostPDF (newest driver) driver. If both are present, delete one of them.
If this is not enough, you can now reinstall the Universal Printer completely in the admin tool / server tile / Printer Management.
