New Release 10.40
New Release 10.40
A new version of TSplus is available now. It is the release 10.40.6.10
The most important enhancement 10.40 Release is the Universal Printer installation.
Now is it down silently (no more Windows pop-up)
Also, if the Universal Printer is removed for any raison, it is re-install automatically at the next reboot.
Some other details has been fixed (minors ones from the 10.40 Beta Release)
Re: New Release 10.40
A new version of TSplus is available now. It is version 10.40.6.27
- RemoteApp client:
Some time the RemoteApp client was not able to catch the clipboard content.
As result, the connection was handled as a dumb mstsc one.
It is fixed now
- HTML5:
When target rdp server is not localhost and target server is win2012 or win10 or newer,
and
originally connecting gateway mismatch in their system language (gateway english > original french etc.)
then this version adds support of fallback time zone.
Usually the gateway sends to target time zones in local language,
as result server does not recognize it and fails to display time zone,
same issue occurs even with mstsc.exe when connecting to Win2008 and older.
Microsoft added since win2012 etc. support for such kind of connections.
So now this feature is supported by html5 client too.
Local servers are unaffected since there original and target do not differ in language.
Ctrl+Ins for clipboard copy and Shift+Ins for clipboard paste,
PC browsers only. (no Mac since not supported there)
Added new variable for cases where user wants to disable secured traffic on http port
webserver\settings.bin > disable_ssl_on_http=true
- RemoteApp client:
It is fixed now
- HTML5:
and
A new version of TSplus available now. This is the release number 10.40.6.29
This version includes the latest compatibility fix for Microsoft's KB4022720 for Win 8.1 / Server 2012 R2.
Please note that TSplus kernel is automatically updated on every TSplus server with a working Internet access, so most of your customers' servers are already up-to-date.
This new version is only for offline servers without Internet access.
A new version of TSplus is available right now. It is version : 10.40.7.4
- logonsession.bin has been changed to handle the case of some users having
a "blue screen" or "black screen" displayed when they did reconnect
- The reconnexion/session capture, resizing handler has been improved in HTML5
- The setup program was hanging some times at the end of the installation process
It is fixed now
- svcr.exe has been changed to avoid anti-virus false/positive issues and unexpected crashes
It is fixed now
A new version of TSplus is now available. It is version 10.40.7.7
- SVCR.exe and startup .exe has been updated to warrant more stability and to avoid
false/positive anti-viruses issues
- logonsession.exe has been changed to allow the start of application using file extensions
for exemple: publishing ttttt.txt instead of publishing notepad.exe
- HTML5 has been enhanced
- The logon process time is faster
A new version of TSplus is available. This version is 10.40.7.30
- In some cases, the logon process was crashing the program svcr.exe
We have strengthen the code to eliminate such event
- Support of the last W2012R2 hotfix is included
- HTML5:
Customizable language strings for file upload/download/listing, now it is possible to change those via language.js
A lot of function depending on the user Session ID stopped to work when this session did change (reconnect, or session captured).
It is fixed now.
Fixed issue in WinXP when copying files bigger than 150kb from \WebFile.
While using for simulating Hyper-V with WinXP, the screen size did not change properly. Now it takes correctly the screen size provided by virtual Hyper-V instance.
Added: Option to select files and to download from file listing menu.
- When using the Web Application Panel
AND the RemoteAPP client
the Universal Printer was not working
It is fixed now
- When using a .rdp file to open a session with RemoteApp mode
AND the user have Microsoft Remote Desktop
A Explorer was displayed and the logoff was very long.
Now it display Folder.exe and the logoff is fast
- When a user was printing several time the same document, in Preview mode,
the next print was never open if the local Acrobat was still open.
It is fixed now
- The name of the print document has been changed to make a nicer display
when using Preview mode
- When application was calling a daughter process and closed, sometime (not always),
was creating a situation where the session never closed.
It is fixed now
- The Domain entry field, when using the Gateway Portal, was required to be enter
before being able to type the logon. This was confusing for the user.
Now the Domain entry field is the first one.
Doing so, the system can validate the Logon because the Domain is known.
- HTML5:
It is fixed now.
It is fixed now
It is fixed now
It is fixed now
A new version of TSplus is now available. This is release 10.40.8.1
- HTML5
The latest build of HTML5 kernel and webime program has been include in this release.
- In the Client Generator the option: "DO NOT DISPLAY SAVE CREDENTIALS" was not working.
This is fixed now
- HTML5
This is fixed now
A new version of TSplus is now available. This is release 10.40.8.5
- HTML5: update by websockets on http address prevented correct working.
It is fixed now
- Explorer was sometime display when using Remote Desktop mode
It is fixed now
- Support of some Windows KB has been add in the kernel
It is fixed now
It is fixed now
