This release is the 9.70 release
It includes all fixes/enhancements made for the release 9.60
- Minor fix on the clipboard handler at logon
- When 2 users were opening a session using the same logon, AND, one application was started (Notepad or the Floating Panel)
the second users was getting a blue screen (without any started application)
This is fixed now
- The new HTML5 kernel has closed one security hole and it enables now
to enhance the security for demanding environments
- For one customer deploying RemoteApp with simple .rdp files we added the support
of such feature. The Universal Printer cannot work when using this king of deployement.
- We improve the speed of logon and the logon process is using less CPU
- We have enhance the fix to avoid issue when multiple sessions are open with the same logon
and when only one application is started.
If any customer is having issues with a "blue screen", most probably this
fix will do the job to remove such issue.
- The HTML5 includes 2 more security enhancement.
If the administrator with to prohibit the file transfer he can now use in setting.js:
disable_file_access=true
New Release 9.70
New Release 9.70
Re: New Release 9.70
A new version of TSplus is available. Release : 9.70.12.21
- When the user had a space into its password, the Generate Client (or the RemoteApp client) was not accepted.
It is fixed now.
- The Web Application Portal has been enhanced to avoid invalid credential. Instead of going to the Windows server, the user will see a
warning pop-up "Invalid credential"
It is fixed now.
A new version of TSplus is available. Release 9.70.12.21
- There was a bug in UniversalPrinter
One folder was not correctly created at the session startup.
It is fixed now
It is fixed now
This is the traditional "Christmas Edition"
What we added for Christmas is:
- A better code for logonsession.exe (more stable, and faster logon)
- A better file transfer feature for HTML5
For several weeks, customer was expecting these enhancement
With the AdminTool you can now select if you wish to use Explorer to select
files to download and you can select multiple files.
You can also prefer to use the "built-in" file download selection GUI
and in such case the new one is more clear for the user.
- We did remove FileTransfer.exe but some customer like to use it.
So, it is now back and available in .../files folder
- The Universal Printer code is more stable
We wish your a Merry Christmas and an Happy New Year.
A new version of TSplus is available and the release number is : 9.70.1.16
- logonsession has been changed to avoid to use CPU when only one application is assigned to a user or group and sessions are opened.
- HTML5 has been updated
