New release 9.60
New release 9.60
- For the first time over the past 10 years, TSplus is now managing the TIME ZONE REDIRECTION.
This is one major enhancement for any customer in large country like USA, Canada, Russia, China or Brasil.
It is also very positive for any Cloud Computing hosted solution.
- The Floating Panel design has been improve and now the administrator has
amazing capabilities to change the background color, the button color...
- The file transfer has been improved with better user interface
- The resize feature on HTML5 has been improved
- The modification of the screen saver in the Client Generator has been removed
- The 9.60 is including all fixes of the latest 9.50
- The feature to be able to use the TSplus shell opening preference has been disabled
on W8/W10/W2012/W2016
- The release 9.60 is including the latest development of the HTML5 client
- The new Floating Panel customization program was started when using the
Task Bar customization tile. It is fiwed now.
- The 9.60 is including a very nice new security feature:
The administrator can set working hours "per user" during which the user is allowed to open
a session
- The 9.60 is also included the first release of the Farm Manager new feature.
This feature is important and will be greatly appreciated by any large deployment
project. The feature will be completed later but the core part in now included.
Please note that we decided to include it as a "Enterprise Edition" mandatory
license. So, to use it, each server of the farm must be of the Enterprise license.
a session
Re: New release 9.60
A new version of TSplus is now available.
- New enhancement of the Floating Panel (nicer)
- New AdminTool feature to customize the Floating Panel
- Fix of the "black screen" issue when editing the Floating Panel
- Fix of the "black screen" issue when using LogoffOnDisconnect
- Fix of the "black screen" issue when application hangs at logoff
- Hide of logon/logoff message for a faster logon/logoff
- Fix of issues with RemoteApp (it was not possible to open twice connection from the same PC)
And... Sometime the RemoteApp logon was not possible
- Much better HTML5 setting for customer who do not reboot the server
(this is a very useful enhancement)
Thank you for the update. Keep on the good work.
It's nice to get a list with enhancements in a new version, but it would be much nicer if you explained
some of these enhancements, like
or
Now we have to look through the AdminTool, what is new or what is different then before.
This would be be greatly appreciated.
Best regards,
Aad Gouka
or
Best regards,
Aad Gouka
A new version of TSplus is available. Release number 9.60.1.28
This release is including several major enhancements and it is nearly what we will get with the upcoming release 9.70
- New Security option: The administrator can decide that using the Web Portal / HTML5 is mandatory. In such case, users will not be able to connect using mstsc or a generated client.
- New nice feature: If a user connect from an IPAD or a Smartphone, the RemoteApp radio button is no more displayed.
- New nice feature: For web file transfer, the administrator can now set 2 different folder on the server. The Upload folder to tell from what Folder the user will select the files to upload. The Download folder, to tell where, on the server, the downloaded files will be stored.
- New nice feature: If a user click on one button the HTML5 top menu, the top menu is automatically closed. To enable this new feature you must set to true the variable:W.newMenuHideOnClick = true; //When new menu used unroll the menu after clicking on buttons.
- New feature: Software editors can now read the following registry value to know what device and what browser have been used to open a HTML5 session.
HKCU/Software/Webdata
- Floating Panel enhancement: The display of icons in the new Floating Panel is much more clear and nice looking. Also, the Floating Panel cannot be moved by the user outside of the left side of the screen boundaries.
- Farm Manager: This exciting new feature is becoming more advanced. Soon it will be the "must have" complete Farm management wizard and from the Gateway you will able to handle every aspect of a TSplus farm.
- FlexiCloud license update problem: We had last week one trouble from our DNS service provider. Sub problem hardly happen but we did change the code to prevent such annoyance to happen again.
- Latest release of HTML5: It include a better detection of user devices, several fixes and the best practice to use 64 bits Java capabilities.
- All know errors fixed during the past 3 weeks are included into this release
A new version of TSplus is available now. Release version is : 9.60.11.30
- Added: Option to set the Universal Printer in Letter or A4 format
(in the Session opening preference of the AdminTool)
- The registry in HKCU to tell a software editor what kind of device is used
by the user to open a HTML session has changed to add the user session ID
- Enhancement of the gesture handler when using tablet in HTML5
- Enhancement of the resize capability of the HTML5 client
- Faster closing process when logoff from a single published application
- Fix of the issue in Web Application Portal when the code is modifyed to
open each application in the same browser tab
- In Application Panel, the title of the windows is now the one specify in
floatingpanel.ini file
- settings modified in remoteapp2.js are no more changed when applying an Update Release
- The Value of some settings under Session and HTML5 Client category can now be saved
- When using the Floating Panel AND no logo, the first application was disabled.
It is fixed now.
It is fixed now.
A new version of TSplus is available right now. Release version 9.60.12.2
- Issue to detect if and Admin is an Admin.
In several programs we have to detect if the user is admin or not.
Unfortunately, even if the user is member of the Administrators group,
on some systems, Windows UAC does not grant him admin rights.
As result, our program cannot detected properly that this user is Admin.
We did change this code to prevent UAC elevation rules to corrupt the expect
behavior of the detection of Admin rights assigned to an account
- Rdpinit.exe and RemoteApp. Rdpinit.exe is the expected alternate shell when
using RemotApp. For years we did not had any problems with this fact.
Recently, we discovered that when rdpinit.exe is in /System32/ but not in
C:\Windows\SysWOW64, Windows was causing an issue with RemoteApp.
Why? We do not know. Possibly, one latest Windows Update are including
this kind of Windows bug. We did change the code of our remoteapp .rdp file
to set C:\Windows\system32, and we added the statement to copy rdpinit.exe
into C:\Windows\SysWOW64 if it does not exists.
A new version of TSplus is available. Release number : 9.60.12.5
- Issues when using RemoteAPP: When only one session per user was selected, AND,
when using RemoteApp, the reconnection was causing issues. Without entering
into details, the current release includes fixes to prevent having issues with
RemoteApp. One side effect of this kind of specific issues was for the Universal Printer
because, possibly, 2 processes was universalprinter processes was running
after a reconnect. An other one was that it was not possible to reconnect at
all after a disconnect.
So, if any customer has troubles with RemoteApp, the good answer now it to
apply the UpdateRelease patch.
- New HTML5 kernel with minor enhancement included.
A new version of TSplus is available now with release 9.60.12.11.
- New feature added to Advanced Security tile
- Better handler of the HTML5 resizing (thanks to Juergen enhancement)
- Icon install problem for the floating panel: fixed
- In some case of reconnect the user did get a "blue screen"
It is fixed now
It is fixed now
A new version of TSplus is available. Release 9.60.12.12
- Small change to handle cases where the system is too slow to handle
fast enough the clipboard at session startup.
