We are pleased to announce the general availability of the TSplus 9.10 release.
It is the first major release of the year 2016 and integrates many great enhancements:
• This version is better than ever and the 9.10 release is compatible with the upcoming Windows 2016.
• The Administrator Tool's interface has been redesigned for more simplicity and efficiency.
• The client generator's interface has also been modified to add more clarity.
• The overall security has been increased to comply with the latest and highest security standards.
• With a simple Drag/Drop, the HTML5 user can transfer files from his PC to the server side.
He can also copy any graphics on his PC and paste it into a Word document running inside his HTML5 session.
These are nice and very unique enhancements you must have.
• According to your preference, the background color of a RDP/HTML5 session can be configured from the AdminTool.
• The Users/Groups assignment has been enhanced for both applications and servers. It works fine for local users/groups as well as Active Directory users and groups.
• Multiple fixes and enhancements have been implemented to improve the 9.10 release and we are sure that all TSplus customers will greatly appreciate it.
This brand new release paves the way for the 2016 roadmap and gives you the consistent corner stone to exceed your Web Portal and Application publishing expectations.
TSplus 9.10 is a major release and we recommend you to download and to apply the Update Release. For more information, go to our Website.
New Release 9.10
New Release 9.10
Re: New Release 9.10
Release Note of 28/01/2016
- The RemoteApp client, now, do not display et annoying "Windows warning" pop-ups.
- On W10, there was annoying system events which was broking the communication after 10 minutes. To eliminate this problem we are disabling the off line service and the power service.
With this change, the sessions are stable.
- We added the file remoteapp2.html to enable autologon with RemoteApp Web client
- The Session Shadowing of the Session Manager has been improved
- The RemoteApp Web client is now using the Web port and no more the RDP port.
- We have eliminate the IE nasty error message
- The Update Release did not update properly some programs that was running, It will be better now.
- The Universal Printer program was not properly updated too. It is fixed now.
Release Note of 29/01/2016
- In order to replace properly the running programs, we did stop them in the Update Release.
Doing so, if the Update Release was started from a Remote Desktop (mstsc) the session would logoff.
We have fixed this. Now the Update Release program can also be started from a
remote session without logging off.
- The Web RemoteApp client was not updated yesterday to include the enhancement of avoiding the display of Windows pop-up.
It is fixed now.
Release Note of 31/01/2016
- Sometime, when no application was assigned to a user, the session was opening with a nice blue background but nothing else. This has been fixed: Now, in such case, the user will get a full Desktop.
- The new numerical signature was not properly applied. Now it is done.
- The Power service was disabled and that was causing troubles to start the WLAN service. Now the Power service is set to Manual (W10 or 2012 R2 or W2016).
- Fix of the logonsession.exe error.
- Logoff button is display when using Floating Panel.
Release Note of 05/02/2016
- Fixed connection error when the Windows directory is not named "Windows".
- Added compatibility for latest Win 10 "Insider Preview" builds.
- Web Portal Preferences GUI: fixed login/password/domain fields disabled when "remember credentials" is checked
- Web Applications Portal:
- Fixed applications icons not found when using Gateway Reverse-Proxy
- Fixed credentials not cleared when using HTML5 and "remember credentials" is disabled
- Fixed "Invalid Credentials" error when the user clicks on "Log-off"
Release Note of 10/02/2016
- AdminTool > Security: fixed the "Help" button.
- HTML5 Client: fixed copy/paste of Word documents on Chrome.
- HTML5 Client: fixed login on Windows 10 phones.
- Gateway Reverse Proxy GUI: the GUI now uses the new servers settings file - this will fix incoherent behaviors.
- RemoteApp Web Client (Windows Connection Plugin): new Setup technology to reduce anti-virus false-positives.
- When using IIS or Apache there was a bug, now fixed.
- when using https the files were not deleted via web-file-manager, now fixed.
Release Note of 17/02/2016
- Avoid the start of a second application if the user reconnects after a disconnection.
- Allowing IE Proxy when using FlexiCloud licenses.
- RemoteApp Client : Allowing the default IE Proxy.
- RemoteAppClient : Adding information if communication error.
- UpdateRelease & AdminTool webroot change : Copy the new files into the different web root folder (IIS or Apache).
- Fix to allow the proper work if the web folder root path is not on the root of the web server.
- Enhancement of the CGI code.
- HTML5: fix bug with third web server + when using https the files were not deleted via web-file-manager, now fixed.
- HTML5: Fix to support file transfer when the web folder root path is not the root folder of the web server.
It is fixed now.
- The HTML5 file transfer algorithm has been completely changed.
(From the user PC to the server side)
As result, it if much faster and it directly goes to the folder set by the Administrator as target folder.
Before, it was copied twice.
One more benefit: the webprint.exe process is using less CPU which can be
important when many users are connected.
- Re sizing of the Web browser in HTML5 was not nice enough.
Now it is perfect. No more black area, or minimize button at a wrong place.
