i have several TSplus Installation with RDS Knight Ultimate. Version is 4.5.11.11.
Should it not be named TSplus Advanced Security since 4.5?
On the german website (https://nord.terminalserviceplus.de/store/) there is only RDS Knight no TSplus Advanced Security.
What is wrong?
RDS Knight is TSplus Advanced Security now?
Re: RDS Knight is TSplus Advanced Security now?
Yes indeed
You should have received a notification email about it. If not, do not hesitate to subscribe : https://www.terminalserviceplus.com/blog/
Yes indeed
Yes, i did receive the notification mail, but i only can only download Setup-RDS-Knight.exe on the german website.
And the update function within RDS Knight also does not offers the new Setup-TSplus-Security.exe.
So i have to install the new Setup-TSplus-Security.exe manually and remove RDS Knight before?
When i download the new Setup and try to install it manually, i get the following error (downloaded the files several times):
