I am trying to use the gateway portal (Not Balancing) with 3 severs, all server (windows 10) are without domain, every is configured, I use the same user name in the servers, however if I login choosing any server always do the login in the Gateway portal server, What are the issues to take into account to use the gateway portal choosing a server without domain?
Thanks,
Gateway Portal without Domain
Re: Gateway Portal without Domain
You need to have not activated the load balancing and you need to have assigned your servers to a user or group so that a choice of server can appear.
Last but not least, you need to check the "Use the gateway portal enabled web page" box in the web portal preference in the admin tool / web.
Refresh your client browser and try again. Now if your username and password are the same on each servers, you may need to add the hostname of each server in the domain field as well.
More information about the gateway feature can be found here : https://docs.dl-files.com/tsplus/gateway
