When I try to install Setup-ConnectionClient.exe in a windows 7 32bits nothing happend the .connet is not associate and the appication do¿id not run like it os not installed, however in the Control Panel show: Connection Clinet Version 11.50.0.6 is Installed
Please help
Re: Setup-ConnectionClient
Uninstall it and delete RDP6 folder if present in C:\users\name of the user\RDP6
Download the setup from here and install : https://www.terminalserviceplus.com/doc ... up-program
Make sure your antivirus is not preventing the execution of the setup and is not blocking the executable in RDP6.
.connect generated in English OS cannot be run in Chinese OS.
