Client Generator
Client Generator
I do not like the current Client Generator. It is way too much to have to install one program and keep it up let alone two. Are you continuing development of the one that generates the .exe and where can I get my hand one it?
Re: Client Generator
We are not continuing to support the previous client generator, however you can still download the latest generator that produces .exe files here, which is fully compatible with latest releases : http://dl-files.com/ClientGeneratorLegacy.zip
Thanks Oliver. Two questions on that note:
1) Where is the latest version of the Setup-ConnectionClient.exe available for download
2) How do you clear the cache on the client when it is a .connect? On the old .exe clients all you had to do was run it with the /clean option.
The client generator permalink will stay the one provided in my previous post. There is no need for deleting cache with .connect files, you need to create a new one if needed or edit the settings of an existing .connect using this procedure below. We are aware that this is not as practical as before but there is no more antivirus warning now.
https://www.terminalserviceplus.com/doc ... ted-client
