i have a running server i need to configure load balancing Feature
i already followed this article https://tsplus.net/forum/viewtopic.php?f=3&t=4415
but it didn't work
could you tell me the steps
as i understood from the article i have to enable the load balancing and add new server in the load balancing section
do i have to complete the rest Load Balancing using a Connection Client ???
thanks alot in advance
Load balancing setup
Re: Load balancing setup
mahmoudsabry
thanks alot for your fast response
could you tell me please if i prepared anew server is that will require anew license or i could use my old one
You will need one valid license per server.
