Greetings,
I try to deply an old application, which only supports 256 colors. So save bandwidth, I would like to set the color depth for that application to 256 colors by default. Is there any way to accomplish that?
Regards
Guybrush
256 colors
Re: 256 colors
We removed the 8 bits color feature from the client generator but kept the option to be set manually by editing the client with this procedure : https://www.terminalserviceplus.com/doc ... ted-client
Edit your connection client and set the color parameter to 8, it should look like this :
-color 8
-color 8
